Where can I found which Exchange I am on
My service from Plus.Net only ever reaches about 250k/s where as my mate down the road who is with Eclipse reached speed of 600k/s but is or should be on the same exchange.
Is there a way, by checking phone numbers, if we are both on the same exchange. I cant believe he can get such a fast rate and I cannot.
Plusnet Staff
Plusnet Staff
Yep, this page:
http://usertools.plus.net/exchanges/
will show you the exchange you are on, the DSLMax section will give you BT's estimate for what the line will support, although it is only an estimate.
Says I should get over 4mb
Sad I don't get more than 2mb
Plusnet Staff
Plusnet Staff
Fixes: 159
At the moment our suppliers are telling us you can only get around 2Mb, as you are on LLU we can try increasing the profile from here but this may cause your connection to drop. Let us know if you want us to try changing this.
 Chris Parr
 Plusnet Staff
