Where I can get firmware update for BT Voyager 205 router
I was just wondering where I might be able to download the latest firmware for our voyager 205 router.
I found this link mentioned elsewhere on the forum, but the page is no longer available.
Searching around the BT voyager site seems to suggest that Plus net (who supplied me with the router when I signed up), might be able to providing the firmware update.
We have firmware 1.3(Z) and googling seems to suggest that there used to be 1.6 and 1.8 available?
Anyone any ideas?
Patch
Moderators note by rogerloxton: turned URL into link to stop it stretching the screen Wink
Looked everywhere but cannot find any other link than the one you gave which BT have taken down.
Your only hope is someone has the download and can email it to you. I doubt PN would have a copy but if no one else replies may be worth raising a ticket and asking.
mherbert
Re: Where I can get firmware update for BT Voyager 205 route
The archive.org cache appears to work, including downloads
Linky
Version is showing as 1.8.
Hope that helps?
moderators note by rogerloxton: had to turn your URL into a link too as it was stretching the screen!
Thanks, that is really helpful. I'll have to remember that site in future!
Plusnet Staff
Plusnet Staff
Fixes: 159
The 205 is in the archive of hardware, but I'm not sure which version of the drivers are available.
 Chris Parr
 Plusnet Staff
Hmmm, the file in the plus net archive just seems to be drivers (I guess for the usb connection).
I have managed to download the firmware upgrade from the web archive link, but when I try and uncompress the exe file I get an error message saying that the file is not a valid Win32 application.
I am using windows vista and have tried running it in compatability mode as administrator, but this has not made any difference.
Just wondered if anyone might be able to affer any help?
Patch
mherbert
Rename the file from TEImageV18.exe to TEImageV18.zip and decompress using WinZip or similar.
After extracting you'll see a file called TEImageV18.bin. This has to be loaded using your ADSL router/modem interface, see Step 7 onwards in the firmware update instructions.
Thanks, I never thought of doing that!
The file is now unzipped, and I am now about to apply it to the router.
Many thanks for all your help
Patch
mherbert
Glad to be of help Smiley
As with all firmware updates, make a backup of the original firmware (if possible), note down current settings, and be careful.
