Wher has the Home options page gone
holdtight
Is it this one your looking for ? https://portal.plus.net/products/upgrade/cbcupgrade.html
if its not i dont know
Eserim
I must say, everytime I pop back to the PlusNet main site I get hopelessly lost with its confusing navigation and maze of pages.
ISomewhere there used to be a page, like this one for the teleworker package
http://www.plus.net/products/residential/teleworker/
with a pull down list to change the amount of bandwidth and see the total price, but for the home packages - want to show it to a potential new customer today, but simply cannot find it anywhere - I can find the prices within the FAQs but the pull down and recalculator is much easier to use.
Is it just me that cannot find it??
Chris
Eserim
Don't know, as when I click on the link I get re-directed to
http://portal.plus.net/index_portal.html
Chris
Link works fine for me.
I get directed to the portal main page as wellHuh
mmmmh.
Just tried it again with no difficulties.
Very strange indeed.
i get..
Teleworker
Save time and money with Teleworker, the flexible Broadband connection for home working. It's a great value way to get online with high-speed, always-on broadband Internet. Choose the data transfer and speed options that match your needs and if your needs change, Teleworker changes with you.
[Edited by triaxor]
helps if I click the correct link :roll:
Eserim
either way, that page isn't the one I was after as it obviously requires a login - the one I was after was designed for potential new customers to quickly see the different options and prices, inclyuding bandwidth.
But it is still odd.
Cheers all.
Chris
Are those who cannot get the page on a lite or premier product. I'm on premier and get redirected to the member centre.
I suspect only lite users can see the page as it only applies to them.
The whole method of charging for broadband has changed in PlusNet for lite products meaning the products page no longer shows the options for inclisive allowance. All speeds now start at £14.99 with 1GB inclusive allowance and you then just add £1.50 for each GB you want to pre-pay for (on the page linked earlier) or if you post-pay (after you actually use it) it will cost £1.75/GB which is added to the next months billing.
Eserim
Peter - thanks, and that may be the answer - however the page I did use before was very simple to see - alas my maths isn't great so it was good to be able to see the mon thly price change as you changed your options - in the same way as the homeworker link I posted at the start does.
Chris
I should also add the costs I quoted above for each GB is now the same for all speeds.
So it's £1.50 prepay or £1.75 post-pay
Any speed lite account
Allowance Pre-pay Post-pay
1GB £14.99 n/a
2GB £16.49 £16.74
3GB £17.99 £18.49
4GB £19.49 £20.24
5GB £20.99 £21.99
etc
Depending on speed it may be better to go premier at some point
holdtight
Peter im on premier and i dont get redirected, link works fine for me
chawke1 sorry it was not the link you wanted i dont know which page
you refer to, was it some time ago you used it ? as peter said there has been
a lot of changes i suspect its no longer used
Likewise Peter,
I'm on premier too.
/scratches head
Erm..
Note the sig below, I'm on Premier too
Eserim
I'm sure I saw it a week or so ago.
Chris
