Whats the chance of getting 7.7-8mb/s??
ok my figures are attenuation 16 and my noise margin is 31 which when i use possible speed tools says 7.7-8mb/s. what are the chances I will see speeds up to this?
1 REPLY
LiamM
MAXDSL is designed so that you should get whatever the max for the line is. And it works out a Max Stable Rate almost on the fly for you depending on your line conditions the exchange will intelligently sync you as high as it can.
So you may well see a sync speed of upto this.
