What speeds are you achieving in the PN speed test for 2mb?
I seem to hit around 1.86mbps. Is that average for this package?
1.94 Mbps here.
KJS
I used to..... until the pipe congestion started. Now its all over the place, I wish we had some good news about the fix and how long it is going to be. Cry
fotobits
I've only just re-graded to 2Mbps, however, currently approx 1.87Mbps.
When I was on 1/2-Mbps and for a short period 1Mbps, it was the upload speeds that seemed to vary widely, producing a very slow all around connection at busy times.
I'm hoping I'll enjoy better all around speeds, throughout the busy periods with 2Mbps.
For your info my current settings are RWIN 50,330 and MTU 1,478. I'm still using W98 and, I understand the max RWIN is 50,330.
Regards
Normally between 1.90 and 1.99.
However as mentioned earlier with the load balancing, if on either of the Redbacks, partticularly #1 for me then it's all over the place.
fotobits
turrell40, it sounds as if your speeds are from adsl.org. Is that so?
My speeds are from the NetPlus test as, I think, was requested by dmdblake.
The adsl.org results are much higher for me, but obviously very inaccurate.
Furthermore, so far my tests are from the Redbacks.
Regards
can vary, one test one minute can result in approx 1.7, next minute just short of 2.0
also found that leaving the rwin blank, or 63272 gives me the best speeds, if I start lowering I get lower speeds. although the lowest I have seen is around 1.65.... so it ain't too shabby Smiley
Noel,
The tests in my sig are from Adslguide.
The first line in my reply refers to what the thread starter was asking.
I wouldn't rely on any speed test as accurate, just a guide, however as tests go Adslguide's test is one of the more reliable - in my opinion of course.
Cheesy
