What's your 2mbit connection's actual speed
I've just got my 2mbit connection, I run the plusnet speed test and it says 1.4mbit?
What is everyone else getting?
Alecto
1.9, but then it is raining Wink
I've asked before, but not found an answer as to what it is reasonable to expect under what circumstances. Mine's been 1.5 on the odd occasion, but normally 1.8 - 1.9
If somebody who knows can comment on what is reasonable and why, it would be helpful to many, I think.
1.85 Mbps on the bandwidth speed test. For a more accurate figure go to ADSL guide here http://adslguide.org.uk/tools/speedtest.asp you should be looking at 220KB/s as a minimum figure. I'm lucky that my connection is rock steady and doesn't waver by more than a couple of KB/s from 230 (pretty much max).
Varies, anything from 200kbps to 1.9Mbps. I would say the average is around 1.3Mbps
Varies:
1.84 Mbps - 1881.2Kbps
Which means you can download at 235.15 KB/sec. from our servers.
1.79 Mbps - 1840Kbps
Which means you can download at 228.6 KB/sec. from our servers.
1.83 Mbps - 1874.4
Which means you can download at 234.3 KB/sec. from our servers.
And via adslguide:
Direction
Actual Speed
True Speed (estimated)
Direction Actual Speed True Speed (estimated
Downstream 1866 Kbps (233.3 KB/sec) 2015 Kbps (inc. overheads)
Upstream 241 Kbps (30.1 KB/sec) 260 Kbps (inc. overheads)
Done straight after each other
Downstream 1891 Kbps (236.4 KB/sec) 2042 Kbps (inc. overheads)
Upstream 244 Kbps (30.5 KB/sec) 263 Kbps (inc. overheads)
Cheesy
LiamM
Your current speed is:
1.78 Mbps
Which means you can download at 228.31 KB/sec. from our servers.
Downstream 1661 Kbps (207.6 KB/sec) 1793 Kbps (inc. overheads)
Upstream 240 Kbps (30.0 KB/sec) 259 Kbps (inc. overheads)
Disappointing :shock:
Thats far below specification and i would be very mad if my line stayed like that for long.
mike001
give me a brake :-)
20-04-2005 16:09:01 1492.2
20-04-2005 14:42:44 1894.7
20-04-2005 14:40:55 955.6
20-04-2005 14:40:20 710.7
20-04-2005 14:06:52 1239.6
20-04-2005 12:43:11 1984.8
19-04-2005 21:54:04 833.7
19-04-2005 21:50:20 753.9
and thay are the better one
it gets worse I some times drop down to under 512
then it stops alltogeter and have to reboot the router
Alecto
1.78 Mbps
Yes, Liam, but should it be regarded as either normal or acceptable? :?:
[Moderator's note by Liam Martin (martinfamily): Fixed BB Quote tags]
Downstream 1851 Kbps (231.4 KB/sec) 1999 Kbps (inc. overheads)
Upstream 245 Kbps (30.6 KB/sec) 264 Kbps (inc. overheads)
1.84 Mbps
Which means you can download at 235.46 KB/sec. from our servers.
Any good? peaktime too.. also the vp status is red on my exchange Shocked
mike001
FFS
20-04-2005 20:36:40 344.9
20-04-2005 20:36:21 407.8
20-04-2005 20:34:45 393.3
20-04-2005 20:34:22 763.3
20-04-2005 20:33:48 471.3
20-04-2005 20:33:30 362.8
20-04-2005 20:33:09 525.6
20-04-2005 16:16:08 1736.3
Getting a bit fed up with this now
LiamM
To be honest, given that ADSL works on contention. It is acceptable. However, I do usually get much better speeds.
Today it doesn't seem to be up to much though.
Why does every one and dog Trust that speed test like the bible. I ran a few tests with it and its in no way accurate. It shows mine as working at 140kB but I run a ftp download from a fast host and i get 230kB. So Don't trust speed tests its 30 seconds when all it takes is a sneeze on the line to slow it up or speed it up beyond the true speed, use a know good FTP sever and dowload a large file to get your true speed, not a 1.3mb file that is all you get from the speed test.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
FFS
You are, i've had numerous conversations & tickets to pn but still am stuck like you.
21-04-2005 22:14:51 479.4
21-04-2005 08:28:01 479
20-04-2005 23:18:48 2047.3
20-04-2005 20:52:18 418
20-04-2005 20:50:16 415.9
20-04-2005 11:49:02 485.4
20-04-2005 10:19:06 477.3
20-04-2005 10:18:23 486.7
20-04-2005 08:04:05 1932.5
20-04-2005 08:03:31 1879.2
19-04-2005 19:51:59 306
Me thinks its time to make a move.....new isp i think
