What's the important info from attenuation log?
Here is part of a log file from my modem. What are the imprortant attenuation info in this log? eg local/remote attenuation, snr margin
WANCommonInterfaceConfig
DSLUptime= 63440
ErrorredSeconds= 2
LossOfFraming= 2
LossOfLink= 0
LossOfSignal= 2
PhysicalLinkStatus= Up
ReceiveAttenuation_dB= 22
ReceiveMargin_dB= 28
RxOutputPower_dBm= 0
SendAttenuation_dB= 10
SendMargin_dB= 24
TotalBytesReceived= 713409161
TotalBytesSent= 242932496
TotalPacketsReceived= 2203341
TotalPacketsSent= 2203341
TxOutputPower_dBm= 0
Uptime= 63440
ChannelMode= Fast
Layer1DownstreamMaxBitRate= 2272000
Layer1UpstreamMaxBitRate= 288000
WANAccessType= DSL
Important:
ReceiveAttenuation_dB= 22 = download line attenuation
ReceiveMargin_dB= 28 = download Signal to noise ratio (SNR)
Good for 2Mbs and faster.
Not so important:
SendAttenuation_dB= 10 = upload line atten
SendMargin_dB= 24 = upload SNR
Thanks Smiley
Is there any data released by BT to show what's the highest connection speed we can achieve with a given attenuation?
No.
Does attenuation affect IPStream and LLU in the same way? ie will one be faster than the other on the same line?
Both are using the same technology (ADSL) so suffer the same limitations regarding line limits. However IPstream line limits (what dB value supports what speed) are defined by BT and LLU line limits are defined by the LLU supplier and they can be (and I think they are) different in favour of LLU I think. i.e. the LLU suppliers are likely to offer a faster service on your line for the same limits.
