What's my IP address?
Trapper_Dave
Is there a way to check at all? I need to access my router remotely, but I don't know the IP address.
Cheers,
-Dave
nairobi
If you're on static IP, you can look it up under My Account -> Connection settings -> Static IP.
if not try: www.whatsmyip.org Cheesy
As @nairobi says, check in your My Account -> Connection settings -> Static IP.
You can use the site linked by @micromecca, but if you are not using a static IP address remember that it may change.
Another way is to use nslookup to check form any other internet connected machine.
W:\>nslookup pilditch.plus.com
Non-authoritative answer:
Address: 84.92.162.231
Note that username.plus.com resolves to your IP Address as standard, whereas www.username.plus.com resolves to your webspace by default.
Njal
That will only show the computers local IP, rather than that of the routers WAN interface though.
not here it doesn't ... i'm on a dynamic ip though, perhaps that makes a difference?
If you have a dynamic IP, it would take too long to update nameservers with your IP address, on the basis that you may only have it for an hour or so (or more or less). By the time the nameservers registered an IP Address to your username, somebody else could be using it.
I forget which products have static, and which don't.
