What's happening?
What's happening?
Got up this morning & found the ADSL connection broken.
Called Cust. Support who were very helpful & suggested a few things (move router next to main socket etc.). Tried these to no avail.
Then - suddenly - connection came up again
But - looking at the figures reported by the router, things look odd .....
(Downstream)
Line speed - 576k (normal)
Attenuation - 47dB (a couple of dB higher than usual)
Noise Margin - 1dB !!!!! (normally 20-ish dB)
I wonder what's going on? The ADSL service seems normal, as does the phone.
I suspect BT have been tinkering around and that noise factor looks decidedly iffy.
LiamM
What's happening?
That SNR is critically low. I don't understand how you can connect with an SNR that low. Basically your line is half noise, half decent signal, thats an unsustainable connection.
Has this just happened the once?
What's happening?
Yep - first time - never had problems before.
Funny thing is, I've been experimenting and found that the 'old' Binatone modem connects fine - if I then immediately disconnect & then plug in the router, things are then OK. IBut - if I then hard-reboot the router, it won't re-connect, until I've connected again with the old modem.
That must be coincidence surely?, it just doesn't make sense
S/N ratios vary - current connection shows 26dB.
I'll leave the thing switched on and hope the problem goes away.
I still suspect BT though - but I suppose the router may have a problem.
LiamM
What's happening?
SNR of 26dB is much better.
I would suspect BT could have been performing some maintenance for a while. If it remains stable from now on, then hopefully it was simply a one-off.
