What's happening to my speed????????
Downstream 703 Kbps (87.9 KB/sec) 759 Kbps (inc. overheads)
Upstream 242 Kbps (30.3 KB/sec) 261 Kbps (inc. overheads)
I am on a 1mb lineHuh? or surpposed to be.
Its getting worse.
Downstream 401 Kbps (50.1 KB/sec) 433 Kbps (inc. overheads)
Upstream 230 Kbps (28.8 KB/sec) 248 Kbps (inc. overheads)
Whats happening??
Downstream 452 Kbps (56.5 KB/sec) 488 Kbps (inc. overheads)
Upstream 235 Kbps (29.4 KB/sec) 253 Kbps (inc. overheads)
Yeah, I'm getting the same sort of speeds. With the bt speed tester I'm getting close to full speed on my 2MB line. Using Plus I'm getting less than 512kb speeds. Guess I won't be downloading anything tonight then...
Speed ok again now, what happened??
Downstream 959 Kbps (119.9 KB/sec) 1035 Kbps (inc. overheads)
Upstream 249 Kbps (31.1 KB/sec) 268 Kbps (inc. overheads)
All speed test from ADSL guide.
Have you tried using the BT speed tester (see http://usertools.plus.net/tutorials/id/27 for details) when you are getting poor results from the AG speed tester? It may be that contention at your exchange is causing the problem.
Tim
Everything seems okay now. Everything was absolutely terrible yesterday evening though. BT speed tester showed full speeds so something was definitely up at + HQ.
looks like i need some serious help here...just done a test on the bt site, i am on 2 meg and this was the result!
Downstream 324 Kbps (40.5 KB/sec) 349 Kbps (inc. overheads)
Upstream 95 Kbps (11.9 KB/sec) 102 Kbps (inc. overheads)
disgrace...may just cancel my subscription now
Here we go again:
Downstream 273 Kbps (34.1 KB/sec) 294 Kbps (inc. overheads)
Upstream 228 Kbps (28.5 KB/sec) 246 Kbps (inc. overheads)
This is getting ridiculous.
you may be gettin throttled or sommit -- how much have you downloaded?
worm
if you are getting those speeds on the BTspeed test then it looks like a BT issue
i was downloading at full speed after 12pm...what a rip off. think bulldog can have my money instead
I do very little downloading?Huh
how about streaming? u do much of that?
No just serfin.
Have they said you have downloaded too much?
No I am well under the limit for usage.
