What's happened to my speeds....
Just got this ticket from PlusNet because i complained about my speeds. My speeds have NEVER reached the 2mb limit ever since i got upgraded, and the VP exchange is green. The connection still says 2mb, but the downloading of websites doesn't feel 2mb, so i ran a few BTspeed tests and low and behold, my speeds were actually still 1mb. PlusNet say they have confirmed i am on a 2mb line, so what can i do?....
2005-05-15
13:04:36
link:CSA Removed
CSC - Escalations Team Assigned : xDSL Status Check OK
Circuit Information
Circuit In Sync
Upstream xDSL Link Info
Loop Loss 13.5 dB
Cell Count 178013
Downstream xDSL Link Info
Loop Loss 22 dB
Cell Count 558808
Start Time Throughput IP Address Browser Operating System
12/05/05 15:03:10 784 217.47.67.153 Mozilla 5.0 Windows XP
12/05/05 14:32:09 874 217.47.67.153 Mozilla 5.0 Windows XP
12/05/05 13:56:53 1217 217.47.67.153 Mozilla 5.0 Windows XP
11/05/05 16:39:52 1423 217.47.67.153 Mozilla 5.0 Windows XP
11/05/05 16:29:00 1078 217.47.67.153 Mozilla 5.0 Windows XP
11/05/05 15:13:15 1406 217.47.67.153 Mozilla 5.0 Windows XP
Regards,
link:CSA Removed
2005-05-15
13:10:55
link:CSA Removed
CSC - Escalations Team Assigned : internal] sent to bt to check vp - 1-5S2Z9N / 01362069
Regards,
link:CSA Removed
[Moderators note by csogilvie: Please do not post the names of Customer Support reps in this forum]
They are throttiling your line ring CS (if you need the number look down :lolSmiley and tell them you are definatly syncing at 2MB and ask them to unthrottle your line they flick a switch you reboot modem you are now on 2MB Cool
why are they throttling the lines when we specifically were told we'd been upgraded?...the past few weeks have been 1mb or less for me...well i'll ring CS tomorrow and get back to you.
ok, just contacted plusnet n waited a while :roll: but anaway, i got through and spoke with a customer service person, n they said they're waiting for action from BT, so i don't know what else to do but wait.
LiamM
If you are being throttled at Plusnet's end, then you should still get full 2Mb speed on the BT Speedtester. The OP isn't.
Sorry, my mistake then. How does the BT speed tester work to tell you a different speed to you are actually achieving beacause PN are throttling you then?
When you connect to the BT Speedtester you are connecting directly to BT's network and bypassing Plusnet.
So you will get the full speed of the line you connect with.
This was the first test i did after my 512 to 2mb upgrade, BT reported that i was capable of 2mb speeds without a problem yet when i connected back through the Plusnet network i was only getting 512k speeds, made a quick call to Plusnet regarding this and the support bod said no problem give it 15 mins then reboot my router.
This fixed my problem.
I get it now, thanks
well when i connected to the BT speed checker, i only got speeds in excess of 1MB connection, not two. So i guess my speed isnt being throttled, but there is a problem with BT on my end. Also, got a ticket back reporting on the BT problem and it said:
[Assigned : Case incorrectly handled by BT, back with them on 1-5SKLNB / 01365446.]
I thought it was plusnet, whereas now i think differently.
