What's The Problem With Web Browsing Please?
To-day my speed tests result in 72.9, 159 and 227 kbps. Only checked because things are happening so slowly. Previously they were consistently above 1770 kbps. Nothing changed at my end.
Anyone from Plusnet able to help?
Cheers
Tom B
You need to eliminate contention at your exchange being the cause of this by using the BT speed tester - details of how to do this can be found at http://usertools.plus.net/tutorials/id/27.
Tim
Already done that. Getting close to top speeds using the BT speed test. Can you get a message to the techies that Plus Net is broke tonight, please?
Cheers!
I suggest you use the official method of reporting problems and raise a ticket.
Hiya Peter,
Thanks for the suggestion, I raised a ticket about an hour ago.
Regards,
Chris
