What happens when the Line is eventually switched over ?
When BT eventually pull their finger out and switch my line to ADSL enabled, what happens to the tone on the line ? Do I need a microfilter to split the voice and data signal ?
I know it sounds like I'm stupid, but its all new technology to me !
Cheers
JASON
RE: What happens when the Line is eventually switched over ?
Jason,
As long as you are using the Plus Net wires only service (which i asume you are if you paid £60 for activation) you will need filters. One for every phone point you have got. What these little beauties do is split the analogue phone signal (for you normal telephone) and your DSL signal (for your turbo charged connection). Easy really! Do you already have filters?
> Jason,
Cheers for that !
