What happens next ?
What happens next ?
Things are getting close now. Applied for 2Mb BB last wednesday, and just phoned BT who told me that the work on my order is due to be completed tomorrow. Whooo Hooo
PN's ADSL tracker however, is still showing Order Submitted to BT, so I am just wondering what will happen after tomorrow. Will that be me active ? or do PN have other things they need to do ?
Haven't received any hardware from PN yet though.
Getting excited now.
Cheers,
Kevin.
Griffo
What happens next ?
PN should update that with your activation date. They will send hardware a day or two before activation. So you will either get it a day before or on the day! Cheesy
What happens next ?
Thanks for that.
So I take it from that, the BT completion date is purely BT's work, PN then have some work to do themselves to set up the account at their end ?
At least at that point things are out of the hands of BT and so should be a bit quicker.
Cheers,
Kevin
Griffo
What happens next ?
Yep that's right. You won't be able to access your ADSL until PN have sent you your username. Which will be something like USERNAME@plusdsl.net
