What does this mean?
kosh2
PN has whoosh tested my line and given me the following, saying it is a marginal line. What do these actual figures mean and is it worth talking to BT?
Circuit In Sync
Upstream xDSL Link Info
Loop Loss 36 dB
Cell Count 130
Downstream xDSL Link Info
Loop Loss 57 dB
Cell Count 1357
First off, it isn't worth talking to BT. There is nothing they can or will do to help you.
BT Retail (the people that you pay for your phone line) do not deal in ADSL queries.
It is BT Wholesale that supply ADSL. These will only talk to there customers, of which only ISPs are there customers.
As such, the only people you can possibly talk to about this, are your ISP.
The actual output suggests are long line, with the possability of supporting upto 1Mb. It would not however support 2Mb.
LiamM
The maximum Loop Loss (Line Attenuation) for 1Mb is 60dB. Therefore, your downstream loop loss of 57dB is close.
It's not worth talking to BT since it's a different department entirely that deal with ADSL provisioning, and these are not customer-facing.
kosh2
Line Gain
I have read somewhere that I shoud check in line gain is on or off. As this will improve the situation. What do you think?
Line gain will have been switched off as part of the ADSL Installation process, so is a null issue.
You could check this with BT if you wish, but it could confuse matters.
