What does this mean?
Is this significant? I installed SG TCP Optimizer. When I tried it, I get the following message:
"Couldn't determine largest possible MTU due to packets being lost"
Your getting packet loss on Adobe so you'll need to try a different
URL like Google, it would only be significant if you got packet loss
on all servers.
You could try running some traceroutes to a few sites using
something like WinMTR or Visualroute this will give you
a more detailed analysis of how your line is performing.
If you run WinMTR for around 5 minutes it should let you
know how much packet loss your getting.
Thanks for the advice.
