What does it actually mean ad how does it affect me??
polsapple
Hi all, help pls if you dont mind.
Below are the results from my D-Link DSL G604T. Now I'm hearing all this info re: you need lower attenuation this and higher SNR that but what exactly does it mean for me in my situation with these results.
I know it's possible to sync at a high rate but not neccessarily possible to be able to download at the full rate. With the results below I can upload at nearly max but my d/l hits a high of approx 4.5 Mb(which I know is good) but I'd have thought it would have been higher??!! Could someone take the time to advise /point me in the right direction on whether that ( -d/l @ 4.5Mb) is an acceptable speed from the results shown??!
DSL Status
Connection Status Connected
Upstream Rate (Kbps) 448
Downstream Rate (Kbps) 8128
US Margin 26
DS Margin 12
Modulation MMODE
LOS Errors 0
DS Line Attenuation 22
US Line Attenuation 19
Path Mode Fast Path
Many thanks for your time. Ta
Smiley
1 REPLY
4.5meg seems OK during peak, give exchange/isp contention and throttling. You should try it during the night say after midnight and you will probably find you get closer to 6.5/7mbit
