What do you reckon my fastest speed will be?
Downstream Upstream
SNR Margin 34.5 30.0 dB
Line Attenuation 22.8 12.0 dB
8mb for you Wink i imagine anyway, thats a very good attenuation to have! and the SNR is pretty good too!
LiamM
Yeah, those are very good figures. Your definately fine for the 2Mb upgrades, and I would imagine you'll be fine for 8Mb when it comes also.
Cloudmaster
So I guess I'm going to be ok then Wink
DS US
SNR Margin 39.4 31.0 dB
Line Attenuation 21.0 13.0 dB
LiamM
Even better cloudmaster.
Here's mine :
DS US
Line Attenuation 31 db 16 db
Noise Margin 26 db 29 db
I must say, I am slightly worried....
you are worried? mine are shocking
DS US
Line Attenuation: 46.1 db 29.0 db
Noise Margin: 25.6 db 27.0 db
gonna get a cable that runs from the router to the phone socket tho (about 15m) cos at the moment ive got
lead from router -> rj-11 to phone socket adaptor -> extension lead -> another extension lead -> socket doubler -> main socket
pretty bad, probably a lot of noise picked up from the lines and connections, so hopefully a high quality belkin cable that goes straight to the microfilter will help
dont have it going through the microfilter tho i dont know if thatl make any difference.
LiamM
Microfilter wont make any difference, since it only makes changes to the voice part of the line. Have you tried plugging into the master socket to see if that makes any difference. Mine is connected by a 15m extention lead to an extention socket which is connected by extention to the master socket downstairs, so quite some wiring. Plugging into the master socket just put the SNR up by 1dB, didnt affect attenuation.
well i think il be just fine Cheesy :
http://cgi.assimulator.plus.com/routerstats.jpg
Tim
[Moderator's note by Liam Martin (martinfamily): Turned image into a link as it was stretching the page width.
LiamM
You really are a jammy so an so.....
Fair play to you mate, I wouldn't be worrying if I were you with those stats.
You must practically live on top of the exchange.
lol, to be honest i havent even seen it before, lol must be near, just dunno where, how far you think?
Thanks, Tim
p.s. thanks for changing it to a link
LiamM
Search for your exchange here - http://www.samknows.com/broadband/search.php and you should get a postcode and MAP. With that you can work out where it is, and how far from you. I wouldn't imagine it's very far at all.
Is it normal to have very similar figures like mine:
Downstream Margin: 31 db
Upstream Margin: 31 db
Downstream Line Attenuation: 21
Upstream Line Attenuation: 20
Everyone elses i see are quite varied with up/down.
So can someone give me an idea on what following figures represent as far as max speed is concerned.
Line Attenation
Downstream 46db
Upstream 12db
Noise Margin
Downstream 18db
Upstream 31db
LiamM
Well unfortunately, your downstream attenuation is going to limit you to 1Mb. You're very close to the 2Mb limit (which is 43dB), so if the restrictions are relaxed a little you may be in luck. Saying that, however, your Noise Margin isn't great. With respect to downstream Noise Margin, the bigger the figure, the better.
wot can i get with thisHuh
Line Attenuation dw/s 45 db up/s 13.5 db
noise margin dw/s 11 db up/s 24 db
kidd
