What connection speed should i be?
Im currently on a 2mb connection from Plusnet. I am connecting @ 2.2mbps is this correct or should it be faster?
1 REPLY
It would appear that you are connecting at the correct speed. 2272kbps or 2.2 mb.
If you are in any doubt as to the speed of your connection you can run the speed test here
