What Speedtester to use?
Have used adslguide.org.uk to test my speed twice.....it worked fine, but now the speed test does not appear in the box..and says java may not be installed?.....it is installed ?..any sugestions please
espresso_mick
RE: What Speedtester to use?
I've been getting an error with ADSL guide and it says 'try again later'; but I've been getting that for a week now.
You could try the following speed test and other tools: -
http://www.dslreports.com/tools
They also have links to 118 speedtests worldwide. One of them (I can't remember which) was really good. (It also showed the congestion of the servers you used.)
Cheers Mick...Ive got it sorted now...seems there was a problem with the Java Aplet? but getting bad results at present ?
