What Router Hardware?
Can somebody please let me know what the current ADSL Router is that PlusNet are sending out?
Regards,
James Mayl
RE: What Router Hardware?
afaik its solwise sar110 imho reasonable bit of kit try the refv at www.adslguide.org.uk good luck
I'm very pleased with mine. Can configure fully stealthed TCP and UDP ports and make it unpingable. Very reliable and good performance. The browser interface is very easy to use and fully features. Not much to do to get a basic service running but you will have to configure for high security as this is not in the defaults.
I also use Agnitum Outpost software firewall for control of application accesss to the Internet and to block various sites. This is fit and forget software. It is very well behaved indeed, unlike ZoneAlarm 3.1.395 which gave Win2K a severe pain. Outpost is also light on resources (Win9X users please note) and, NO, I DON'T HAVE SHARES in Agnitum.
Smiley
