Well Done
Well Done
Just Upgraded to ADSL from Dial up connection.
Took just 10 days. I went for the PCI Modem option and everything worked first time.
So far Download Speed has been great.. Keep up
the good work Plus.net
>> Info for other New users <<
If you are using XP then you need to enable the
Use Passive FTP (Firewall and DSL Modem Compatability) If you don't then Windows Update, stops working.
