Webspace transfer limits?
Ive read nowhere otehr than that i am limited to 100mb max on my webspace. Just out of curiousity, is there a transfer limit on your webspace, or is it just added onto my upload/download monthly total?
Cheers
Yes, there is a daily transfer limit which is usually the same as your webspace limit, in your case 100MBytes/day.
See Webspace FAQ which can be found by clicking the help button at the top of the page, then clicking the webspace icon under the self help section.
Thank you Cheesy
