Website Problem
Website Problem
Hello guys i have a problem viewing a certain site on my client pc that routs through ICS, on the gateway pc which is directly connected to the modem the site works fine!! but the error that i get is page cannot be displayed, my pcs are connected up with 2 network cards and a cross over cable and of course ICS running: Help appreciated
Wink
Website Problem
if you've ever installed kazaa lite on that computer you may find that it has installed a new HOSTS file (c:\windows\system 32\drivers\etc\). depending on the site you're trying to visit it may be redirected to localhost (127.0.0.1). if you open yours HOSTS file in notepad (or any other similar text editor) you can do a find for that domain.
Website Problem
Cheers, i dont think kazaa lite has been installed on the gateway pc, or this client pc either, the site that wont work on the client pc is www.http-tunnel.com but it works fine on the gateway pc with the modem. i was thinking mayb i haven't setup ICS correctly or something.
Thanks for your reply Wink
