WAN LAN or ATM
WAN LAN or ATM
no experience with PCI modems but I would have thought ATM seeing as adsl uses PPPoA (i.e. ppp over ATM)...
WAN LAN or ATM
This was the first questiom my particular PCI ADSL modem setup asked any idea what I should select ?
It selects the appropriate drivers to load. Running under windows home xp.
Any help appreciated.
WAN LAN or ATM
ATM as far as i know
WAN LAN or ATM
Hmm.... my ADSL PCI modem required me to select WAN drivers for it to work, seeing as the internet is a kind of (very large) WAN.
Thomas
WAN LAN or ATM
But then again, WAN interface so definitely WAN.......I think errr :?
WAN LAN or ATM
It's pot luck unless you are able to obtain the manual.
WAN sounds correct, seeing as the internet/ADSL network is a WAN.
ATM sounds correct too.
However, both have very different meanings, and could both relate to the different protocols.
This isn't somthing that could easily be guessed. Only documentation can distinguish the different between the two.
WAN LAN or ATM
I'd suggest trying ATM first. The WAN option may well be PPPoE.
So try ATM, if it doesnt work you can always unistall and reinstall it as WAN.
Chris
WAN LAN or ATM
its the Wan drivers the manual gets it wrong
ed: heres a good install Guide
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
