Voyager Alternative
Voyager Alternative
:roll:
I'm fed up with my Voyager 205, can you guys advice me for an alternative to this router/modem
I'm planning to signup with vonage, and they are offering me Linksys RT31P2 Can I use this device to replace Voyager 205, Please advice, if not, which is the best alternative from linksys brand....Waiting for Reply....
Voyager Alternative
Hm, no firewall built in... I'd consider looking what else is out there.
Draytech do a good range of VOIP routers with firewall etc built in.
Look at http://www.broadbandbuyer.co.uk and put voip in as a search criteria.
Vonage also have a reputation for locking their hardware to their service only...
Voyager Alternative
Nope..its not because of firewall absense, I'm unable to open ports..and forwarding and stuff like that...
But the biggest dis advantage is that it heats up a lot and lots of connectivity issues, that results in frustration....
So I wanna a switch to a reliable brand like...Linksys...
I'm still waiting to hear about the possibilty of this particular linksys brand ....can anyone suggest me ...(check my initial post)...whether this model of linksys has got a modem router option..or is it just a router......Please advice....
Voyager Alternative
That was what I meant. It does not appear to have a built in firewal...
