Voyager 2091 wireless router security
green_tomato
I have just installed my Voyager 2091 wireless router and got myself successfully connected to Plusnet. Then my neighbour suggests that there are security issues with having a wireless router. That someone could be sat outside my house accessing my broadband/computer without my knowledge? Is this correct and what should I do about this?
frattonpark
You need to secure you connectons. If you obtain a manual for your router then its easy to do
1. Switch on the WEP security using a key created by you
2. Hide your network name so that other people can't see it
3. Eac of your connecting PC's will have a machine access code (MAC Address) Add these so that only comms from your pc's will accessible over your network
Hope this helps
green_tomato
good advice but
That sounds great advice but to techie for me, can you talk me through using simpler language, thanks
