Voyager 205 problems
Hi all, I hope someone can help me with the problem I'm having. I recently suffered a catastrophic harddrive failure resulting in it needing to be wiped. I'm now back online but my router keeps crashing.
I've opened ports through my firewall and forwarded these (so I'm connectable for bittorrent).
The problem is that since this I can't seem to connect my router to my PC using an ethernet cable. The ethernet light on the front is lit sometimes but not at all most of the time. As a result, I have to connect using a USB cable, which (I think) causes my connection to crash frequently. I then have to reset the modem to reconnect.
Anyone have any ideas what could be causing this? Before my harddrive went kaput I had no problems connecting using the network card. Any input would be greatly appreciated!
Greg
