Voyager 205 Config Manager stuck in Quick Start
Help!
When I open the Voyager 205 Config Manager, I can't get it out of the Quick Start function - It just sits there and refreshes every few seconds showing the connection status
When I click on the Troubleshooting or Advanced buttons on LHS of screen, they change to reflect that, but the main window just keeps on refreshing with the connection status
How can I break out to access the Troubleshooting and Advanced functions?
Many thanks
Alan
Alan
I am having exactly this problem. Did you solve this?
Mark
I am using a firewall (Zonelabs free) and AV (Norton) but it still doesnt work when I disable both!
Hi Mark
After several suggestions from PlusNet support, which I tried, we were unable to fix the problem and PlusNet sent me a new Voyager 105 modem, which is a more simple version than the 205, and it has been working solidly ever since
Good luck
Alan
Alan
Thanks for the advice. FYI I managed to install the latest firmware (v1.Cool using the tftp client mentioned on the corz site - though this did not fix the problem. I can work around it using the other links on the corz site - specifically http://corz.org/comms/hardware/router/205_admin_pages.php which I can use to access all the admin options without using the routers own menu pages. It sounds like PN should have advised you to do this too. Nevermind!
Cheers
Mark
