Voyager 105 configration page
I'm trying to access the configuration screen of my BT voyager 105 USB modem to have a look at port forwarding but I can't access it. Any IP I have tried does not work any ideas please.
Me too
I'm having the same problems... is it even possible with this modem?Huh
craigbrass
I didn't think USB modems had configuration pages at IPs, only routers. Correct me if I am wrong tho.
LiamM
Nope. All ports will point to your PC already. Make sure you're firewalled up and simply allow the programs you need to receive incoming data, access to the internet. Voila.
As for USB modems having config pages on IP addresses. Some infact do. Take the Binatone PlusNet provided, that did.
The support pages for the modem at: http://www.voyager.bt.com/usb105/pcdiagnostics.htm
Talk about the following procedure for access diagnostics, the screen shot also has a config button.
"The modem comes with a "user friendly" GUI (Graphic user interface.) Please see diagram below. This can be used to diagnose possible problems connecting to your ISP.
Open the windows control pannel
Open BT ADSL Modem Icon "
HTH
Stuart
