View my usage
View my usage
Is the VMBU issue still ongoing ?, it seems to reporting my usage higher than it should be.
View my usage
Same here - I have used 500mb this month if you add up the individual days, bu the overall total shows 2gb used. They haven't updated the portal on this problem now for 6 days
lowry
View my usage
The "View My Broadband Usage" issue is still ongoing unfortunately. However, PlusNet seem to be devoting alot of tiem to finding a solution to the problem. I have not noticed any issues in the last few days.
matt Wink
