View my usage?
View my usage?
Doesn't 'View my usage' work when you're on ADSL?
RE: View my usage?
why do you want it adsl is an always on connection so you dont realy need it. If your interested on how long you are online for or how much you are downloading/uploading get DU METER or something like it.
RE: View my usage?
I've probably misunderstood the situation. I thought that the always on bit referred to the BT line.
I had it my head that the fair usage concept still applied to some extent.
Must admit that I haven't read all the 'small print' (well any of it in fact...)
