View Usage
View Usage
Can someone please answer this simple query.
Do the View Usage figures only give the usage between own PC & the internet?
Does any traffic on web/cgi servers count or do these have unlimited use?
Thanks,
Dave
View Usage
Yes
No and you do have daily bandwidth/traffic limit on your website (whether it's on www or cgi server), they don't have unlimited traffic. See Webspace FAQ item 2 for details.
View Usage
Thanks Peter.
I thought I understood the situation but then I have had another thought. Is the traffic counted in both directions? If my web-site downloads a file and then someone downloads it from there, are both counted towards the bandwith?
The same for my home use. Are up/downloads both counted? I guess they are.
Dave
View Usage
The view my usage includes all data that is sent in either direction just down your ADSL line. It does not include and information that may be downloaded by others from your website. But it will include any data you upload or download to your website because that goes over your ADSL line.
