Very slow speeds, timeouts
The last few days I've been getting very slow speeds with many web pages timing out. I switched my router off for about an hour a couple of days ago, which seemed to make a difference for a short time, but everything has continued to be be intermittantly slow. My P2P seems to manage 5kBs at best whereas a week ago it was 500kBs+...
I have been trying to do a BT speed test this morning, but I cannot get past the entry of the telephone number/checking user details. (it's been sitting on this for 10 mins and as I write this...)
Plusnet Staff
Plusnet Staff
Fixes: 159
Can't see any reason on your account for the speeds suddenly slowing down, everything is set the same as previously.
What results do you get on an alternate speedtest?
 Chris Parr
 Plusnet Staff
Just after posting I again tried the BT speedtest and it got to the entering the username and said it did not recognise me as being on this telephone line... Tried again several times and managed to get a speedtest:
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 6500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7616 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 5626 kbps
Seems like resonable speeds to me, but this is not reflected in a variety of websites; e.g. www.mx5ocforum.co.uk forum.miata.net/vb/ and others...
Now switching everything off, including router, while we go out for an hour or so...
The alternative speed test shows 6052... :?
and everything seems to have speeded up again... Will switch off and see what it's like after everything's reset and had a rest...
Plusnet Staff
Plusnet Staff
Fixes: 159
Let us know if things slow down again and we'll look into it for you.
 Chris Parr
 Plusnet Staff
After a rest, everything seems to be back to normal... though the P2P server crashed for unknown reasons during the night.
Guess it must be the overweight american OS that can't take too much exercise :-)
Thanks for the responses, Chris...
