VPN
VPN
i have a netgear DG632 router have forwarded the ports for VPN and setup the server connection on the computer i want to connect to but when i try to connect i get error 733 and i cant ping the static IP.
is it because i havent set it up as a static IP in the router. if so whats the default gateway etc for plus net.
hope someone can help
VPN
I doubt you will get VPN to work with a Netgear. We tried for ages with netgears support and it just doesnt work. It does vpn pass through which means it lets it through un altered but thats about all.
see
http://kbserver.netgear.com/kb_web_files/n100858.asp
You dont say what o/s your using at each endpoint?
gkhewitt
VPN
The OP seems to talk as if all he needs is a pass-through.
We've been using a pass-through on the DG834G for the past few months without any problems. However, this is only a PPTP. If the OP is trying to do IPSEC, it may be a different story.
If you're doing PPTP (client -> server, as opposed to IPSEC which is server-server) You should just need to forward port 1723 to the IP of the server.
Good luck!
