VPN over ADSL
VPN over ADSL
Does anyone know if you can use VPN over plus net ADSL? Ive tried by had no success.
Ben
RE: VPN over ADSL
You would need a real addreess for the machine running VPN for it to work. If you have a single static IP and this is assigned to a router then you will be unlikely be able to set this up.
Kind regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Technical Support ................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: VPN over ADSL
If, however you have a selection of external fixed i.p addresses (I apparently should have 4 when my account finally becomes active) and a dedicated machine for the VPN, is it then possible?
Daniel
Daniel Rosewarne
inframes.com ltd
daniel@inframes.com
Publishers of
What The Papers Say
http://www.wtps.co.uk/
RE: VPN over ADSL
I use VPN over ADSL to connect to work, it has been working fine but now it kicks me off my connection every 63 minutes. But apart from that it works.
> Thanks
> Ben
Vince Dunne
RE: VPN over ADSL
> > Thanks
> > Ben
> i Also have a call outstanding with PlusNet to see why this keeps happening, as a person i work with has the same problem.
> Vince Dunne
Vince Dunne
RE: VPN over ADSL
I use it no problem from work to home. As long as the tunnels are built correctly you shouldn't have any worries.
Angus
RE: VPN over ADSL
Don't think you will get 4 IP's you will be assigned 4 but you can only use 2!! Dont waste loads of time (like I did) trying to get the other 2 IP's working.
> Daniel
> Daniel Rosewarne
> inframes.com ltd
> daniel@inframes.com
> Publishers of
> What The Papers Say
I Use VPN from home to office and Office to Home and no Problems.
retrospek
RE: VPN over ADSL
Hi Ben,
I use VPN for working from home occasionally and have no problems. I'm using the Nortel EAC client which uses the IPSec protocol (not that I fully understand what this means).
Don't forget that the router will need to support IPSec Passthru for this to work correctly.
My original router was a ASUS and I could not get it to work. So I then bought a Intertex IX66 (which is a great machine) and it worked first time.
As soon as I'm connected I can stay on the connection all day and don't get disconnected.
Cheers, Mark.
retrospek
RE: VPN over ADSL
Hi Ben,
Cheers, Mark.
RE: VPN over ADSL
What's the point in having a router (in my case Netgear DG814 with IPSec passthrough) if it doesn't let you pass through? I have a static address via the DG814. Would it work if the Plusnet assigned IP address was dynamic?
