VCI snd VPI Numbers
VCI snd VPI Numbers
Hi All,
I just bought a Belkin ADSL Modem with built-in wireless routher. Can anybody please give me hints and tips on installation? I think all I need is the VCI and VPI number, as my IP address is NOT static. Does anyone know where I can find them? At the moment I have normal wired ADSL Modem, but this works for just one PC.
Many Thanks
Anil
VCI snd VPI Numbers
VPI - 0
VCI - 38
It should be a pretty straight forward setup of just entering your username and password. If you need any help don't hesitate to ask. If you need anymore help can you give us the model number of the router just to speed things up for you Cheesy
VCI snd VPI Numbers
Hi Andy,
All sorted and done!!!! Installation was much simple that I thought. Thanks for your help. Cheesy
