Using my account from a different location
I frequently work from a different location and would like to access my Broadband account from a different phone line. Is this possible
1 REPLY
To access your broadband account from another location, you must ensure firstly that you are not connected at your home.
Secondly, the second location must be provisioned with Plusnet Broadband.
Thirdly, the second location must be provisioned in the same realm as your home account.
For example, my login name in my router is sallyandjames@plusdsl.net, whilst my mothers is tunley@plusdsl.net
So long as I am disconnected at home, I can change the login details on her router to mine, and all useage will be charged to my account.
If her account name was tunley@plus.com though, I wouldn't be able to do so.
Hopefully this explains it for you?
