Username
Username
is it possible to have a different username in my E-mail address. if not am i able to change my plusnet ADSL/E-mail username? thanks
1 REPLY
Re: Username
You are I am afraid stuck with the user name you signed up with and that forms part of your email address. The only way you can change it is to sign up for a new account which would be expensive for ADSL.
You do have some other options though.
1 You could start a free account under another name and use that as your email address.
2. You could register a domain which would give then you a different email name.
3. you can always change the first bit of your current address before the @ sign
