Usage
Usage
Hi everyone, im not quite sure if PN have there heads screwed on, but check out this...
http://www.plus.net/support/broadband/network/sustainable_usage_guide.shtml
^^ Scroll down a little and it says Option 1 Premier Users get 30GB a month
http://www.plus.net/residential/broadband/broadband_premier.shtml
^^ Yet look at the Usage limit on that page for Option 1, its only 15GB
So what am i actually getting? I'm on Option 1 btw. I'd be greatful if someone could help me. Thanks, Mark
Fixes: 133
Usage
Have a look at this thread:
http://portal.plus.net/central/forums/viewtopic.php?t=42167
HTH
Forum Moderator and Customer
Usage
It doesn't really answer my question unless i missed something?
Fixes: 133
Usage
How I read this is that your Option 1 limit is 15GB with restrictions starting at 10GB.
After going over the 15GB limit if you then exceed 30GB your download speed will be restricted to 128Kbps until the end of the current billing cycle.
If you go over 30GB a second time then the 128Kbps limit will remain in force until you upgrade to a higher priced option.
HTH.
Usage
Oh ok thanks. bit harsh dont u think? lol
Usage
Oh does this 15GB apply if u use it up Online Gaming and Browsing? or is it just for P2P's, Torrents?
Fixes: 133
Usage
AFAIK (please correct me if I am wrong) all internet activity counts towards your peak-time usage Sad
HTH
Usage
I hope it doesn't count mate, i love gaming... and i'd hate to be having like 100+ ping or something lol... PlusNet are good for game pings btw, i can get like 5 ping in servers in UK. Cheesy
Fixes: 133
Usage
Oops, sorry, what I meant to say was;
All internet activity during the peak hours count towards your Peak-Time usage.
Shockedops:
obitus
Usage
Apologises for hyjacking your thread, but am thinking of upgrading from 2mb to 8mb on plus Broadband Premier (option 1 at 15gb) if i go over this amount would i be billed extra or does my download rate just lower and the monthly bill stays as it is?
Thanks in advance.
Usage
am thinking of upgrading from 2mb to 8mb (and from?) Plus (to?) Broadband Premier ... if i go over this amount (15 gigs) would i be billed extra or does my download rate just lower and the monthly bill stays as it is?.
Hope it edited your question right.
The answer is you would not be billed more if your downloading+uploading goes above 15 gigs, your download and upload rates would lower, and ultimately Plusnet would try to hassle you into migrating to Premier Option 2 .
just visiting
Ray
Usage
Thats correct, but remember that speed management begins at 10Gb, and then becomes more severe 12.5Gb, and finally gets totally restrictive at 15Gb.
Don't get it thinking you can sail all the way up to 15Gb before management starts.... Wink
Usage
I would just switch to Premier anyway, i had Plus.. and i couldn't stand the slow speeds.. 8MB soon though W00T!!
Usage
8Mb soon?
How soon?
Didn't you see the announcement that BT have suspended the upgrades?
Edit:
Added more:
Here is the announcement.
and
Here is the discussion on it.
Sorry.... :?
BigDaz
Usage
HTH.
So if you don't upgrade it'll stay at 128kbps forever?
