Usage Chart
Usage Chart
Just had a look at this, to work out which package I should need, and I am mystified by the fact that on the 2 days when there was no one in the house and the PC's were off that there has been a little usage, about 0.5 mb.
How can this be, especially as the PC's were off.
Also does just surfing cause usage and if so what would looking at say bbc.co.uk for 30 mins be?
Many thanks
Usage Chart
Are you connecting via a router?
Surfing, will be included as usage as your using the internet. As for how much for looking the beeb, it would be difficult to say, depends on how many pages you look at, refresh or links that you click.
Aaron
Usage chart
Hello
I am connected by a wireless router that was not off. Is this something to do with it?
Cheers
Usage Chart
The fact your router is never off, could be why your recording 0.5MB used when all your PC's are off. I don't know enough about ADSL to provide an answer as to why I'm afraid.
Usage Chart
yep thats definatly is your router if its anything like the ones I've had will always be sending out a few packets of data every now and then. Its nothing to be worried about its just the way they operate.
Usage
Thanks fellas. Cheesy
