Upload speeds
Upload speeds
I see no mention on the main +net site of upload speeds. I use my connection both ways and have a 512/256 setup and am going to "upgrade" to the download "up to 2MB" version. What does this mean in terms of upload?
Upload speeds
The upload speed is fixed at 256 ( 32Kb/s ) regardless of your download speed.
Upload speeds
All current IPStream based connections from BT (which PlusNet use) have a fixed max upload speed of 256Kbs.
Higher speeds may be possible when the high speed (>2Mbs) connections arrive Q2 next year, when they will increase to a max of 432Kbs for 50:1 contented products and 832Kbs for 20:1 contended products. All speeds are still subject to line conditions.
If you want a faster upload speed now then LLU supplies this (upto 512Kbs currently) but that means moving to another ISP as PlusNet currently don't have such a service. The other very expensive option is SDSL which PlusNet do supply - see the business products.
Upload speeds
up to 768k is avalible on an 8mb llu line
pacem
Upload speeds
I assume you mean 32KB/s the difference between a bit and a byte is significant.
Paul.<><
Upload speeds
Heh thanks for the info guys - was just curious Smiley
