Upload speed
Upload speed
Noticed today and yet again my upload speed is or has gone to pot. I noticed this through my ping on a game server, usually i get 60 ping a few days on and off i have been finding that i am playing with 100+ ping.
RE: Upload speed
This is the second test i copied and the difference in upload speed is just a few kbps difference.
Downstream 449 Kbps (56.1 KB/sec) 484 Kbps (inc. overheads)
Upstream 90 Kbps (11.3 KB/sec) 97 Kbps (inc. overheads)
Brickinit
RE: Upload speed
it must depend on which server you are connected to as i have just done a test with these results
Downstream 468 Kbps (58.5 KB/sec) 505 Kbps (inc. overheads)
Upstream 243 Kbps (30.4 KB/sec) 262 Kbps (inc. overheads)
malc
RE: Upload speed
Remember, all connections are now RADSL.
The rate adaption takes place on the uploads, and should never affect the downloads.
See the RADSL FAQ on adlsguide.org
http://www.adslguide.org/qanda.asp?faq=radsl
