Upgrading from plus to premier option 1?!
is it worth, it will my speeds at peak tmes improve?
You may also wish to consider PAYG.
If your daytime usage is below 12G per month, then it may be cheaper than Premier, and all your traffic will be in the Gold queue.
Chilly
my usage is about 5-6 gb a month total usage off peak and at peak times.
So I have opted for PAYG 6GB @ £17.99 peak times which will be more than enough.
sam
Hi julesp1970,
I have responded to your ticket about usage times.
thanks
