Upgrade
Upgrade
I have finally got ADSL and am on the basic 2mb package at £14.99 capped and wish to go for the unlimited one at £21.99.
Can someone advise me on how to do it?
Thanks.
Upgrade
At the very top right of the portal (beside logout) you should see an upgrade button.
Click that and follow the instructions.
That should sort it.
Upgrade
Thanks for that.
Just before I do it will my connection be cut off or just upgrade without me noticing?
Thanks.
Upgrade
If you have not requested a speed change it will not affect you except for a short period when your IP address will be changed. You may still not notice this until you reboort your router or disconnect/reconnect your modem.
If you also want a speed increase to 1 or 2Mbs then there will be a short downtime period when BT disconect you but this should only be for a few minutes at most.
Upgrade
Thanks for you help. Got it sorted in the end.
garywood84
Upgrade
petervaughan,
Re your post above: "...your IP address will be changed..." - do you mean that once the regrade to 2Mb has been completed I'll have a different Static IP address? Is there any way to avoid this? I'd prefer to keep the one I've got!
Gary
