Upgrade to 8 mb
Upgrade to 8 mb
How would i find out if my line is suitable for 8mb. i am on 2mb at the min. I would be grateful for any advice.
Upgrade to 8 mb
Go to >>here<<
Where it says 'See how fast you can go' enter your phone number & click on check speed, this will give you an approximate figure.
Upgrade to 8 mb
What ADSL equipment do you use.
Check to see if it can report line stats and post them here.
Info on how to find this for many of the common routers/modems are shown here.
Upgrade to 8 mb
cheers fella says i should be able to get 8mb.
Upgrade to 8 mb
Got these stats if this helps
ADSL Line Type GDMT
ADSL Line Coding FAST
Line Attenuation (Down):20 (Up):9
Noise Margin (Down):30 (Up):29
Total Output Power (Down):0 (Up):0
Current Rate DownStr: 2272(K) UpStr: 288(K)
ADSL Line Status UP
FEC(FAST) (Near):0 (Far):0
FEC(INTERL) (Near):0 (Far):0
CRC(FAST) (Near):0 (Far):0
CRC(INTERL) (Near):0 (Far):0
HEC(FAST) (Near):0 (Far):0
HEC(INTERL) (Near):0 (Far):0
Showtime last(sec) 1168699761
ADSL_FW_Version 0.49
ADSL_Board_Type Annex A
Upgrade to 8 mb
They look very good and you should be able to get near the maximum for Max (about 7.5Mbs) - note the BT page is only an estimate, not a guarantee.
However, it does depend on your line quality and this will only be discovered once you get upgraded but with those figures I would certainly recommend requesting the upgrade. There is also the BT/exchange/ data rates which can sometimes go wrong but again you won't know until you are upgraded.
What ADSL equipment do you have? If its a USB modem I would recommend you change to a router as it can often give much better results and achieve higher speeds and be more reliable.
Upgrade to 8 mb
Did have a modem but i went and got a router because i wanted to be able to connect my laptop up wireless.
jape
Upgrade to 8 mb
I'm currenty on 2Meg.
What should I expect with these stats ?
Line Attenuation Dwn 43.0dB Up 25.0dB
Noise Margin Dwn 12.0dB Up 30dB
If they are ok do I have to request to be upgraded or are automatic upgrades still happening ?
[/img]
Njal
Upgrade to 8 mb
I think you have to request it at the moment:
http://www.plus.net/support/broadband/network/upto8Mb.shtml
Regards
Neil
Upgrade to 8 mb
Thought i would ask in here right. I am still getting 2mb just run speed test on here when i do a speed test on think it says that my upload is 0.4. i am finding that the download is more stable but is there anything i can do to improve the speed.
Thanks for any help.
Plusnet Staff
Plusnet Staff
Fixes: 159
Upgrade to 8 mb
@coleman86
what does a BT Speedtest give you and what does the Stable Rate say ?
 Chris Parr
 Plusnet Staff
Upgrade to 8 mb
On the stable rate link i got "Your current broadband speed is 8000 Kbps". But on the bt speed test it will not take my login details. what should i bet entering?
Plusnet Staff
Plusnet Staff
Fixes: 159
Upgrade to 8 mb
Full details of how to run the BT speed tester are available at
Linky
This should give you all the information you require.
 Chris Parr
 Plusnet Staff
Upgrade to 8 mb
The same username as you enter for your router- this is normally in the form <username>@plusdsl.net
Therefore in your case I'd expect this to be coleman86@plusdsl.net
Upgrade to 8 mb
Thanks lestones
i have just done the test and it comes out with the following
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1978 kbps
