Upgrade to 1MB broadband
craigbrass
I may upgrade to 1MB broadband now that the price is only £29.99 for unlimated bandwidth. The only thing stopping me is it currently says I cannot recieve 1MB broadband because of my distance away from the exchange. Will this change after the 6th of September? I am not sure of my distance away from the exchange but I assume it is somwhere in the city centre and I am only a short distance away from that.
It might do you would have to wait and see
If you have 512K now there should not be a problem getting 1Mb after 6th Sept as the 1Mb line limit will be what 512K is now (60dB).
