Upgrade Tests for PlusNet (thanks bob)
RE: Upgrade Tests for PlusNet (thanks bob)
Can someone confirm plus.net realm at my exchange was upgraded or fixed at all?
Results from your most recent broadband speed test recorded on 09 November 2002 at 15:53:05.
Your Connection
Direction Actual Speed True Speed
Downstream 62 Kbps (7.8 KB/sec) 71 Kbps (inc. overheads)
Upstream 239 Kbps (29.9 KB/sec) 274 Kbps (inc. overheads)
Surely this has to be the slowest blurbband.. i mean broadband in UK...
My speed results at 17:15 on Saturday pm:
Downstream 470kbps actual, 540 kbps true
Upstream 246kbps actual, 282 kbps true
Before the upgrade, I was getting about the same downstream speed, but upstream little faster than a 56k modem.
I am in the plus.net realm, located in Oxfordshire.
Here is my speed
Downstream 466 Kbps (58.3 KB/sec) 535 Kbps (inc. overheads)
Upstream 73 Kbps (9.1 KB/sec) 83 Kbps (inc. overheads)
AARGGH!!!!
Downstream 472 Kbps (59.0 KB/sec) 542 Kbps (inc. overheads)
Upstream 245 Kbps (30.6 KB/sec) 281 Kbps (inc. overheads)
please stand up
please stand up
Results from your most recent broadband speed test recorded on 09 November 2002 at 17:48:31.
Downstream 77 Kbps (9.6 KB/sec) 88 Kbps (inc. overheads)
Results from your most recent broadband speed test recorded on 09 November 2002 at 19:29:11.
Downstream 120 Kbps (15.0 KB/sec) 138 Kbps (inc. overheads)
Upstream 235 Kbps (29.4 KB/sec) 270 Kbps (inc. overheads)
Results from your most recent broadband speed test recorded on 09 November 2002 at 20:30:03.
Downstream 56 Kbps (7.0 KB/sec) 64 Kbps (inc. overheads)
Upstream 240 Kbps (30.0 KB/sec) 276 Kbps (inc. overheads)
Results from your most recent broadband speed test recorded on 09 November 2002 at 21:31:49.
Downstream 41 Kbps (5.1 KB/sec) 47 Kbps (inc. overheads)
Upstream 236 Kbps (29.5 KB/sec) 271 Kbps (inc. overheads)
Results from your most recent broadband speed test recorded on 09 November 2002 at 22:43:22.
Downstream 109 Kbps (13.6 KB/sec) 125 Kbps (inc. overheads)
Upstream 237 Kbps (29.6 KB/sec) 272 Kbps (inc. overheads)
Even if, somehow, London Poplar exchange was the only one in the country where contention ratio of 1:50 on that 10Mbit chunk of 155Mbps SDH ATM is actually in use I still won't believe all 1000 possible contended Plusnet users on that chunk are active 100% of the time throughout entire Saturday.
So.. let me ask this straight - Plusnet - are you throttling bandwidth on some exchanges?
