UpGrade
UpGrade
Im Just wondering on a matter,If there is lots of people upgrading on Plusnet does that not mean the connections will start to get slower on 1mbps if there is alot of people Upgrading?.I have upgraded to 1mbps Premium if that means anything..
thanks
Jon
1 REPLY
UpGrade
PlusNet keep a very close watch on bandwidth used on their central pipes and have bandwidth in reserver (which can be enabled at very short notice) when it is needed.
So there should not be any issues with PlusNet running out of bandwidth and causing slowdowns on ADSL connections.
See available bandwidth.
