Unlimited usage for £47 a month with the plusnet premier
hi
there is a way of getting unlimited usage with the premier package by doing the following
getting BT to install another phone line so you can run 2, 2 meg premier packages from both of them .
so you can break the usage limit with one of them and then the next month use the other one
From Carl
I beleive this subject has been raised before.
This is technicaly possible.
LiamM
Wouldn't that be £43.98 per month then?
You could combine the two in the offpeak hours for 4Mb downloads and when the 8Mb comes into force, well, 16Mb Downloads. Nice Cool
£43.98/month for 16Mb... Not bad!
dragona
i was reading up about it last week
Bonded DSL ... you should be able to do it with any ISP shouldnt you?
anyway found this:
http://www.freestuffjunction.co.uk/bondedcd.shtml
run it off a flash disk then no expensive cisco router Shocked
hi
yes a 16meg connection would be nice but a bt line rental cost needs to be taken into consideration which is around £3 a month.
I might think about doing this unless plusnet does a package to cover this option say £47 unlimited 2 meg connection for the premier package
16 meg connection a 1 meg file downloaded in 2 sec
from Carl
LiamM
A while ago, I started this thread. Apparently Plusnet do not support Bonded ADSL. I'm sure you could get some software that runs locally to do all the work though.
